Error message in KMplayer playback
I am playing video with KMplayer, Playback seemed to work for me, but startup was extremely slow and the screen froze for ten seconds. A message appears with gen_ml.dll is corrupted. How to fix it?
Hey Emil flores!
Do not worry about this problem. I also had the same problem. I really searched every page on internet to solve this error. Anyways I managed to solve the problem. I could not believe that I single step will help me to solve the problem.
I would like to recommend you the same simple step. What you need to, on your ML in plug-in folder you just have to change the owner and security permission. No matter if you are administrator or not, this solution will work for you.
I hope that you will not get this error message again
Thanks
If that’s what you see when you start KMPlayer, the DLL file is probably corrupt and cannot be loaded. Try reinstalling the media player if you still have its installer. Download Revo Uninstaller Freeware. Follow the instructions to download and unpack and then install it. Once installed, start Revo Uninstaller then select KMPlayer from the list.
Click “Uninstall” then follow the instructions to completely remove everything it created on your computer. When it is finished, restart your computer. Run the installer again to install it back. Also, if you haven’t updated the media player yet, go to KMPlayer Official Home Page and download the latest version. KMPlayer is a cross-platform media player that can be installed on Microsoft Windows and OS X.
The latest version supports Windows 2000, Windows XP, Windows Vista, and Windows 7. Microsoft Windows 8.x and Microsoft Windows 10 are not officially supported. For Mac, it supports OS X 10.6 Snow Leopard and higher.
