donaldtbyrd
50 points
Posted on - 05/09/2012
I am receiving an Error Message for the LMS. Can someone please tell me why is this happening?
LMS Message (Thu Feb 02 2012 17:21:35 GMT -600 Central Standard Time))
Failed to save your progress. HTTP status Code of 0 was returned.
Press OK to save your progress again or press Cancel to close this course.
Hi, Donaldtbyrd,
Solve this.
You can get rid of these LMS.exe errors if you follow the required steps on how to avoid LMS.exe failure on your PC. It may be lots of steps but it is easy to accomplish. To do this:
Step 1: Download and install LMS.exe File Repair Tool software.
Step 2: Run the software and let it fix your registry.
Step 3: Move all the LMS.exe virus and terminate it.
Besides, it will also create a modified study on how to remove the LMS.exe errors. Always keep your computer up to date to avoid getting such viruses. If these LMS.exe hits your PC, it will surely caused a real PC hassle. To get rid of these upsetting LMS.exe errors, uninstall it into your computer. Always use a guaranteed registry Optimizer to perform full registry scans.
