Error message that my Adobe Flash Player is not up to date
I already have an Adobe Flash Player, but an error message says that mine is not up to date.
How do I update my version?
Any suggestion is highly appreciated.
Hello Bryant, all you have to do is, go to Control Panel and look for the flash players that is currently installed in your system. Just simply uninstall them all if its more than one. And after that.
Restart your computer. Then go to adobe.com and get the latest Flash Player available and install this to your computer. Then your problem will be solved. Hope this help you in finding solutions to your problem. Have a nice day!
First of all go to your Flash Player's "About me" and check your version of flash.
Go to your start line and type "check for latest updates", after searching check for "Flash updates", and if any found click and install that update and restart your system. Hopefully it should work.
If it doesn't work then go to start line and type "uninstall program", Search for Flash and uninstall it from your system and go to the Adobe original website and download and install latest flash.
Hope that works!!
