Error Message Nokia Asha 202
what do error occurred. Unable to complete operation (006) means and how can it be rectified? Please help with this error message.
If this is the first time it happened on your device, try rebooting your phone then try it again. If it doesn’t work, try turning off your phone, remove the back cover and then disconnect its battery. Keep it detached for about 5 – 10 minutes to clear the phone’s system. After this, install the battery again then start the phone. Repeat what you are doing and then see if it works.
If you are on the process of installing an application on to your phone when the error pops up saying that it is unable to complete, check again the application’s requirements and supported devices. Visit again the site where you downloaded the application and then check the application’s requirements there. Or maybe if you are in the middle of the installation when the error happens, check if your phone is receiving a good amount of signal. It is possible that the installation is downloading its data files when the error happened which is may be caused by an interruption in the connection due to poor signal reception. You may also try doing it again during off-peak hours so that there’s not much web traffic going on in your network.
Hi the author of the question,
The error pops up at your mobile phone its means ERROR 006 NO CONNECTION.
So the error itself will give answer.
What you’re going to do?
Try to check if the signal of the WIFI you used is full signal or good signal if you can make it fast access on other web site it means you’ve a good internet signal.
After checking the signal try to restart your mobile phone because that is some method or steps to recover some error occurred in all devices by restarting or turn off the device. Then try the application you used to do.
Be sure the internet connection is good and full of signal. That is the very important. You always remember error 006 means no connection.
I hope my suggestions help you a lot.
Notifications
