Error message occurs when open Convert EDI POs to Sales Orders screen
This message occurs when I open the Convert EDI POs to Sales Orders screen. Can you provide me the solution? Any help would be really appreciated. Thanks in advance.
System Message 15823 Error reading Transaction Log Directory. Process aborting.
OK
Answered By 0 points N/A #174699
This is a simple case of having invalid paths specified. What you should do is to check EDI set up. After checking, you should compare the paths. They should match that of the EDI machine. If they match each other give it around twenty minutes to normalize then try opening the Convert EDI POs again to sales orders. It should work by then.
