An error message “Random Error” keeps popping up
Hi experts,
Using the Windows OS I am getting Random Error which is really annoying to me. I want to know about this error and how to remove this annoying error? Any help would be appreciated. Thanks in advance. The error is given as below.
Random Error just to annoy you.
Answered By 0 points N/A #175921
Hi Shane M Heck,
The file that is annoying you is a VB script and is not a computer virus, it means that you can locate and remove it from your computer freely without taking such risk, to remove it, it seems also that it is on the startup folder of the start all programs menu, go to start > all programs > startup and open that folder, if you have not seen any file inside the folder, show all its hidden files, the file is a ninja scroll like icon with color cyan on top.
