I am using my notebook in ‘Sky Drive’ and when I delete any section, it gives me an error message regarding incomplete synchronization.
The message says that it is not synchronized in this notebook.
Please help me.
Error message regarding incomplete synchronization
Hi Gayle,
Here are some steps to be able to fix the error message regarding incomplete synchronization.
Just follow any of the methods below:
Debug your server
The server on the log file must be modified
You must edit the file %ifolderdirectory%/data/simias/simias.log4net
Look for level value info in xml. Cahnge it to level value debug and save the file
Change your directory to directory /ifolderdirectory/simias/data/simias/log/simias.log
And then run this tail command tail f-simias.log I grep could not find file
Start the synchronization again after you restart your computer. You can also read and get some idea on this link.
Zorian
You just simply download the error repair tool from the net and then you just simply install that to your computer after installing the error repair tools to your machine you just simply restart your PC after that you just simply start scanning to your system and then after finishing the scanning to your PC just simply repair the found errors and then try to defrag your PC to start defrag the system just go to the desktop then click the start menu and then try to go to the my computer then right-click the drive then select the properties then you just simply select the tools then you can see the defragmentation just simply click the to start defragging your computer.
Ben
