Error Message in setting up OpenEMR4.0.0
Hello experts!
I get an error message setting up Openemr4.0.0. It shows an error message.
Here it is below –
Warning: substr() expects parameter 1 to be string, array given in C:xampphtdocsopenemrlibraryclassesInstaller.class.php on line 297
When I attempt to run Openemr I face another error like this – Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/London' for '1.0/DST' instead in C:xampphtdocsopenemrlibraryclassesPrescription.class.php on line 188
After trying 3 days I managed to install it. But I get different error messages with different error code. The normal error message includes error code 188. But after 4 times it appeared, it showed different error code like 189, 190 and 397. This is so frustrating.
Please someone help to resolve those error codes and tell me how can I run this software properly.
