I receive this error message on Clicker 5 sometimes.
It is the one I posted here.
Unexpected Error System.NullReferenceException
Clicker 5 (version 5.25.2610.20706)
  at Xceed.SmartUl.SmartControl.OnMouseMove(MouseEventArgs e)
  at System.Windows.Forms.Control.WmMouseMove(Message&m)
  at System.Windows.Forms.Control.WndProc(Message&m)
  at System.Windows.Forms.ControlnativeWindow.OnMessage(Message&m)
Please click 'Continue'.
                   Exit Application   View Log…   Continue
I already viewed the log and saved it, so that I can report it to Crick Software. What should I do in the meantime?
Thanks for any help.
Error message shown often on Clicker
Hello Deborah G perry,
i think you are worried about your clicker.Don't worry today i am going to tell you to solve the persisting problem.
Firstly I want to discuss about system.null reference exception message which inform us that the object reference is not set to noting or null. You should set an reference before set up and make a clear reference check and use manual for if needed.
i think after that you will be able to solve your problem.
Best of luck
