Error message shows during opening of Office Outlook
The error “Cannot open your default e-mail folders. The server is not available. Contact your administrator if this condition persists.”  is showing during opening of the Microsoft Office Outlook although the connection has been refreshing repeatedly. What might be the problem?
Best Answer by Zorian Crust
Answered By 80 points N/A #99609
Hi Delois,
To be able to avoid getting that error, please follow the instructions below:
Click TRUST CENTER on TOOL MENU and then click ADD-INS
View the application extensions and the add ins that are categorize by the following
Document Related add ins –  You need to list all the template files in an open documents
Disabled application add ins – all the add ins should be automatically diasbled
Inactive application add ins – All the present add ins on your computer should be listed. Some examles are com add ins and xml schemas
Avtive application add ins – All the registered extensions that are currently running on your computer should be listed.
Add in has command features that increases the productivity of your computer. You should manage them to be able to avoid errors like what you have got. I hope it helps.
-Zorian
Answered By 5 points N/A #99610
Hello user
This may be a problem with the Exchange server you were using. Check whether any others in your network has this problem or discuss it with the administrator of the Exchange server.
See whether you set the settings right in the Microsoft Outlook account settings. Are all settings right such as the Username and password or any proxy settings set right. Get all the information by contacting the admin.
look into your firewall settings. Check whether MS Outlook is allowed to connect to the network. This is not necessary if you use Windows Firewall as it will be preset to allow Outlook.
