Error message shows when installing the HP Laser Jet printer driver
I have these errors messages when I try to install the driver to my new printer HP Laser Jet P1005. Drivers are new, the printer is new and still I have this error. Can anyone help me to fix this? What could be the main cause of this error? Thanks!
Copying Files…
HP1006.DLL
To C:WINDOWSsystem32..hewlett_packardhp_laba3b
Cancel
Copy Error
Setup cannot copy the file HP1006.DLL RetryCancel
Ensure that the location specified below is correct, or change it and insert “Hewlett Packard” in the drive you specify.
Copy files from:
C:Program FilesAvago-HP Browse…
HP Laser Jet P1005 Setup Wizard
Plug in the USB cable and power on your printer.
This will allow the Hardware Wizard to complete the installation of your printer.
Caution: Before you connect the cable to the printer, always power off the printer, otherwise the printer might be damaged.
