Error message on starting Civil 3D 2012 64-Bit
I started Civil 3D 2012 with 64-bit on my Windows 7 64-bit PC. I received the error I posted below.
Actually, I don’t consider this as an error but a message and I just want to know how I can get rid of it.
The message can be seen in the command line when trying to start Civil.
Do you have any suggestions on how to make it go away?
Thanks you in advance.
AutoCAD Text Window – Drawingl.dwg
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: CUSTOM
Customization file loaded successfully. Customization Group: EXPRESS
Initializing….
There are no valid MS Jet providers installed……Done.
Regenerating model.
*Cancel*
AutoCAD menu utilities loaded.
Command: _RIBBON
Command: COMMANDLINE
Command:
Command:
