Error message: unable to locate original file
Hello everybody,
I need to get rid of my endurance with venture and wanting somebody there has to reply.
It explored the concept board and discovered identical issues, however it is within the Trados 2007.
I am working well with SDL Business 2009 considering at the end of last season and this is initially I've arrive over this.
My venture requires an approximately 130-slide PPT submit that was actually a Keynote (Mac) submit but had been changed. The second changed data offered no issues. UPDATE: Right after attempting to start the effectively designed focus on interpretation I sad to say I found out despite the fact that it had been changed in to a PPT, the data would not start in PowertPoint.
I do nothing to modify anything about the data (i.e. title or extendable) and designed a frequent venture file as I usually do. I have used TM created by place in 2007 (Also applying without issues for the secondary data). Right after finishing the interpretation the pursuing issue concept for the big data file:
Fault: Incapable to find unique file: [title of data file]
Please duplicate this unique submit into index above and do it again.
No index described "above" everywhere.
Also attempt on generate the company new file, re-copying the unique submit from the USB keep I gotten it with, once may and may not shifting the name (has a some unique people in the list) however, still receive the similar concept each time.
The unique data is still in the unique file, and the multilingual data is also in the venture file.
Is there anyone had an identical issue and know the solution was?
I would be significantly value it.
Thank you.
