poohbowen
Posted on - 06/20/2012
Hello all,
I am unable to use the Service.msc active. It is displaying this Error message:
One or more ActiveX controls could not be displayed because either:
1. Your current security settings prohibit running ActiveX on this page, or
2. You have blocked a publisher of one of the controls.
As a result, the page might not display correctly.
Want to get rid of it. Please help me.
Error Message Unable To Use Service.msc active
Regarding with this query most windows 7 operating system service.msc, or gpedit.msc also with regedit do not open directly even if you log-in as administrator of the system.
When you perform this task, warning a message will pop-up saying one or more active control could not be loaded with the following error.
1. Your current security setting prohibit running active x control on this page.
2. You have blocked a publisher of one of the following control as a result the page might not display correctly same as image below,
To solve and get rid of this error message please follow steps below,
1. Click start button
All programs
Accessories
Click run
2. Type regedit and hit enter
HKEY CURRENT USER
SOFTWARE
MICROSOFT
WINDOWS
CURRENT VERSION
INTERNET SETTINGS
ZONES
3. Look for a key which name is not encoded in numeric characters and delete
4. Exit on the registry editor
And it’s all done, Hope it helps with your problem.
