Error message upon downloading software
I downloaded radiosure v 2.2 but couldn’t run it. When I started it an error message appeared which was: “Encountered an improper argument"
And the software was disabled. Please advise me a solution.
Dear Abel zurich,
You have downloaded radiosure v 2.2 but could not run it.
Your downloaded software file is possibly affected by virus, that is why error message is appears. You have to clean virus from your computer by using an antivirus. Download an antivirus and install it in your computer, or if previously installed an antivirus in your computer then update your antivirus and scan the whole computer.
Then download again the software and try to install. I hope it will solve your problem.
You must download the latest version of radiosure.
If there still showing problem, then you try to install windows again & then download an antivirus & scan the computer. I hope it will be ok.
Thank you.
It seems the program has not been updated since 2012. Until now, version 2.2 is still being offered both as free download and the Pro version. The official site has not released an official list of the system requirements but other websites provide the system requirements so users can check on them. It is designed only for Microsoft Windows.
It will not work on other operating systems like OS X, Linux, Windows Mobile, or even Symbian. RadioSure supports Windows XP, Windows Vista, and Windows 7. If that error always appears every time you start RadioSure, try reinstalling the program. But first, make sure it is compatible with your operating system. Also, try installing the latest Service Pack for your OS.
If you are using Windows Vista, you can install Service Pack 2. Go to Windows Vista Service Pack 2 to download. If you are using Windows 7, download and install Windows 7 Service Pack 1. If you are using Windows XP, update to Windows XP Service Pack 3.
