Hi all.
This morning, I’ve found an error message when I am running Netbeans 7 in my Windows PC and unable to find the past splash display. So I need to try this command line.
netbeans.exe -J-Xmx512m
Guys, can you give me suggestion or possible solution for this? Any suggestions would be greatly appreciated.
Error:
JVM creation failed
Error message when I am running Netbeans 7.
Hi michael ;
I want to show you how to fix the "JVM creation failed" problem in your NetBeans programs.
1. First go to the directory where netbeans is installed ( C:/program files/NetBeans 7.0)..
2. Then open the net beans folder..
3. Go to the “etc” folder (C:/program files/NetBeans 7.0/etc)…
….here you will see a “netbeans.conf” file..
4. Now open this file in a notepad bloc-notes…
5. Go to the notepad file and use (ctrl + f) then a window was appear like in the figure :
Click “Haut” (or “up”) Direction button then tape “384m” in the “rechercher” ( or “find what”) box. Click “suivant” ( or “ find next”) button… you find the “384m” notice …
6. Now change the “384m” notice to “200m” ..
7¾ When you close the notepad file you must save.. click “oui” (or “yes”) button ..
Now run your NoteBeans ….
Enjoy.
points
Working with NetBeans on a Windows XP/Vista this is a common error. It’s solution is simple. Just add an extra option in the configuration file and see your problem has gone.
To fix this error go to NetBeans configuration file under: C:Program FilesNetBeansetc
Open "netbeans.conf" into Notepad.
Orginal configuration row is:
netbeans_default_options="-J-client -J-Xss2m -J-Xms32m -J-XX:PermSize=32m -J-Dapple.laf.useScreenMenuBar=true -J-Dapple.awt.graphics.UseQuartz=true -J-Dsun.java2d.noddraw=true"
Now simply add this extra parameter to the above row:
-J-XX:MaxPermSize=128m
MaxPermSize is connected to the Permanent Generation. In Java, Permanent Generation has the Class Object. Netbenas is developed in Java and at startup generates Class dynamically. So, when the default size of Permanent Generation becomes too small that time this error appears. To solve this issue just adjust the size of the MaxPermSize.
After adding the extra parameter finally the row will be looks like:
netbeans_default_options="-J-client -J-Xss2m -J-Xms32m -J-XX:PermSize=32m -J-XX:MaxPermSize=128m -J-Dapple.laf.useScreenMenuBar=true -J-Dapple.awt.graphics.UseQuartz=true -J-Dsun.java2d.noddraw=true"
Now restart the NetBeans.
