I have some solution and suggestion that i hope it will help you to solve your problem. As you mentioned your problem when you launch EMPIRE EARTH II the message problem appeared as "FATAL PROBLEM and the link that you provided" i have suggestion for this try to uninstall your java or remove it with the use of control panel and then go to remove/add hardware then remove JAVA and then try to download the LATEST JAVA as of now then.
REBOOT your computer and then launch again your game if this is will work and If this not work for you it means that you install a corrupt file or missing file and try to reinstall new and i advice if you use to download this game i suggest also don't interrupt while downloading file because interruption of file may cause corruption of file.
If not work again try to contact the provider of that game for some advice and guide.
I hope it will help and gain information to solve this issue.
Try to uninstall and then reinstall the game. Go to Control Panel and then Add/Remove Programs. Locate the game and then right-click it to uninstall. Or try to open Paint and then save the picture as splash on a 24-bit bitmap file.
Save it under C:EE2srcEE2 folder and then try to start the game again and see if it works.
If you want to play “Empire Earth II”, make sure your computer meets the requirements. You cannot play a game that is not compatible with your computer. “Empire Earth II” supports Windows 98, Windows Millennium, Windows 2000, and Windows XP. Windows NT, Windows 95, and higher are not supported.
Empire Earth II
“Empire Earth II” requires 1.5 GHz Intel Pentium 4 or equivalent AMD Athlon XP or faster processor, 256 MB RAM, Microsoft DirectX 9.0c-compatible video card with 64 MB video RAM, Hardware T & L, and Pixel Shader support, sound card, 1.5 GB free space, and 4x optical drive.
The game “Empire Earth II” is a real-time strategy video game developed by Mad Doc Software and published by Vivendi Universal Games on April 26, 2005. “Empire Earth II” is the sequel to “Empire Earth”, the 2001 bestselling game developed by the now-defunct Stainless Steel Studios.
1....
