Error Message When Opening Microsoft Excel 2003
This error message always appears when I open Microsoft Excel:
Cannot find XLQUERY.XLA!
What does this mean?
If that error always appears every time you open Microsoft Office Excel then it is really something that needs fixing. If you installed an add-on or a plug-in for Microsoft Office Excel then it is possible that it is the reason why a file went missing. But if you did not do anything on your software then you can try fixing this by doing a clean installation on the application.
First, try restarting your computer then see if you can launch the application without receiving that error. But if this doesn’t help, uninstall Microsoft Office Excel then restart your machine when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostic test on your computer, use a disk utility application like PC Tools Performance Toolkit. Install Microsoft Office Excel then see if this fixes the problem.
Notifications
