Error message when recovering CAD drawings
I was using a tool to recover and audit AutoCad drawings.  However, errors were found after recovery and audit, see below the message I got.  It said errors were found but was fixed, right?
Is there anyone from this site who can interpret the message for me so I would know what to do next?  Thanks a lot!
Errors were found
Recover .dwg file
Total errors found during recover: 0.
Audit recovered database.
57739 objects audited
Total errors found during audit 73, fixed 73
Best Answer by SaifAli2011
Answered By 0 points N/A #93386
When an error occurs, diagnostic information is recorded in the acad.err file, which you can use to report a problem.
A drawing file is marked as damaged if corrupted data is detected, or if you request that the drawing be saved after a program failure. If the damage is minor, sometimes you can repair the drawing simply by opening it. Otherwise, you can use the following:
Answered By 15 points N/A #93388
When you were recovering and auditing the AutoCAD drawings using the tool that you have mentioned, the process seems to have encountered some errors. But as the error message indicated, all the errors that the tool came across were successfully fixed, and therefore you do not need to worry because the drawings should be just fine and the application itself too.
Have you tried executing the application and using the drawings after you encountered that problem? In case you have not done that yet, then I will request you to do so. It most unlikely that you will get any problems when running the application and using the drawings since all bugs that were found have been already fixed.
-Clair Charles
