When I am trying to register WinZip an error message is coming.
Please see the screen shot of the error message.
Please help me to solve the problem.
Thanks in advance.
WinZip
WinZip could not save your registration credentials in C:ProgramDataSinZipWinZip.sureg.
Could not write data to file, error code = 5.
shoaib1
200 points
Error Message when registering WinZip
this error indicates that you don't have the appropriate rights to save data in the folder indicated or save changes to a specific file in the folder. If you have encountered this error, please try the following:
Click on the Taskbar Start button
the text box just above Start type: C:ProgramData
Press the Enter key on the keyboard
Delete In the WinZip folder
Open WinZip and enter your registration information
If deleting the WinZip folder does not work for you, you might try temporarily turning off the User Account Control (UAC) as follows and see whether that helps:
