Hi, I’m receiving an error message in outlook express which says “Host application not working”. I use outlook for my email messages and now I’m stuck. This error comes up while starting the outlook program. Please help me find a solution to my problem. Thank you
Error message when starting ms outlook
Did you try reinstalling outlook.
1. It seems that some configuration of the present system and the application is creating problems.
2. The scenario lies with saving the file in the list of windows and then specifying the problem detailed way.
3. The host means the server cannot be connected for the work. Check the network connection.
4. Check the configuration that is not working for the Outlook to o its work. The schema lies compact and venerable to the software solution to the schematic diagram and solution to the necessary purpose at its best in the life time.
5. The Microsoft Office be reinstalled if not done with the above.
