Error Message When Trying to Customize Blog, How Can I fix it?
Is there any fast and easy way to change the background that any error won’t appear? You might just help me out with this because whenever I try to change the background I always see this error message.
I have followed the suggested steps yet I still fail. Of course, just like any other novice blogger I would want to customize my page but it seems to be hard. I have tried new versions of both Firefox and Google Chrome but nothing has really changed. Does it have something to do with the search engines I am using?
Any help will be greatly appreciated.
Thanks all.
Answered By 0 points N/A #133627
Hello James,
Changing blog background is a great way to fascinate you readers, not just the contents of your blog, but there must be somewhat an attractive look to indulge the readers, as you have experience some error in changing your background, please try to analyzed on the error message on what it is pointing to.
In many cases bloggers got an error in changing the backgrounds because the file it self did not meet the required file specification, most blog sites accept only files in JPG, GIF or PNG format, the size it recommends for the images is 1800 x 1600 or greater, and  300 Kilobytes or less file size.
Try to check if your customization meets the standard.
