I have a Youwave application installed on my android phone, but the problem is, when I tried to open it I got an error message saying “Sorry! The application Calendar storage (process.com.whatsapp) has stopped unexpectedly. Please try again.” please help me fix this problem.
Error message when using Youwave on android phone
Hello Maricel,
I have read your concern Youwave application. An error appeared when you tried to open the application and wanted this to be fixed. Is it right?
In the error message you’ve posted, it is clear that there’s nothing wrong with Youwave. The only thing that you have to fix is WhatsApp. You may reinstall this program by going to “SETTINGS” and then “MANAGE APPS” and choose the program then select “UNINSTALL.” This will clear the application and you may now able to reinstall it back.
Another cause of this problem is the improper execution of the application. Once opened, try to exit the program in proper way because this may lead to corruption of file, sending you error messages like this. If this really happened, kindly follow this instruction to modify the ending process. Go to “HOME MENU” and select “SETTINGS” then “APPLICATIONS” and “MANAGE APPLICATIONS” select the program “WhatsApp” and end with “FORCE STOP.” This will then reboot the YouWave and WhatsApp will proper work again.
I hope I am in the right track of understanding your concern and give you a hand to fix the problem. I hope this information is of good help.
Good Luck!
Mali
