Error message which says ‘No DHCP’
My operating system is Windows R2 2003 and I have installed the IBM X 346 server.  Every time I am switching on the server it is not properly booting up and gives some error messages which says ‘PXE51 / DHCP’, ‘It is not received DHCP’. I don’t know why this is happening. Please help me to get out of this problem. Thanks in advance.
Best Answer by ljubisa993
Answered By 0 points N/A #101263
Hello
I think that i know how you can  resolve this problem.
First what do you need is to restart DHCP. I will attach picture on this post so you can see that.
After restarting DHCP you must do next:
1. Renew your IP:
– You must open the command menu
– Click on Run>CMD
– Now type:Ipconfig/release
– Then type: ipconfig/renew
2. Re-configure the WDS
That would be all.
Answered By 0 points N/A #101264
Many thanks Ljubsia993. I knew it techyv can help me. It was a little bit hard to do for me the way you said, but finally i did it. Lot of thanks.
