Hello everyone,
I have got an error message when installing Harmony Builder on Windows 7.
HarmonyBuilder-Demo Installer
Message
Install failed
Error running the install, Ant run failed – examine the error logs for details
                      OK
Does this also happen to the full version?
I am using only a demo installer. Why did this happen?
Is Harmony Builder compatible with the version of my OS?
Could someone help me about this?
Error message while installing Harmony Builder on Windows 7
I think I'm able to help you.
Just do the following to get rid of the problem:
Windows seven has high security settings on the program file folder, which prevents the installation from completing. As you overcome the problem, just create a different target location for the installation when promoted during processing the installation. Don't forget to choose a location with no read/ write restrictions. On the other hand, you can alter the security settings of the program file folder.
Is it ok?
Hathy
Dear User,
You can easily fix this problem. Follow these steps,
First make sure you have installed Java. If not go to  http://www.java.com/en/ and install java.
But however the main reason for this error is the security protocols used by windows 7
In order to fix this you can simply create a different target location for the installation,
When prompted during the installation you have to choose a location with no read/write restrictions.
Thank youÂ
