I have got a quick question for you. I have just recently installed the Malwarebytes' Anti-Malware program.
I tried to check for any available updates before I ran my first scan with the new software.
However, I received this error message instead and then, the system shut-down.
I have attached the screenshot of this error.
An error occurred. Please report the following error code to the
Malwarebytes' Anti-Malware support team.
Error code (0,0)
OK
Please tell me why this happened.
Error message while installing the Malwarebytes’ Anti-Malware program
Try reinstalling the software and make sure that you are able to delete the preferences and cache of the application. Most applications provide this option when uninstalling so make sure you uninstall first before you install it gain (with the latest version)
If you do not see any option to delete the preferences and cache during uninstalling, go to drive C > program files and find the folder for the application and delete it. You may also need to do the same in the App Data folder
Hi Jody B Alcaraz
The error 732 means, it is a problem of internet connecting. Maybe proxy setting or Firewall or some virus blocking to the internet. Alongside these solution my recommendation also visit this Techyv post.
Malwarebytes error – Looking for Solution
