Error message while posting a page
Do you have any idea why I get this error message:Â There was a problem with the Database: error code 1146:
Table ‘hha.p1votx_taxonomies’ doesn’t exist when posting a page.
I don’t know what I did wrong, but this starts to happen after I enable the Bonus Fields extension.
Could that be the cause?
Thank you for reading
Error:
error code 1146: Table 'hha.pivotx_taxonomies' doesn't exit
– If your are in the process of setting up PivotX, you should review your Database connection settings.
– If it worked before, you should check if the Mysql database engine is still running on the server
