Hi Experts,
I have got an error message while sending a picture through Picasa’s email by choosing “Gmail”. The error message says “An error occurred trying to send your message. Please try again later”.
I do not understand what is the reason behind it? Do you have any idea regarding this issue?
Please help me to find it out.
Thanks in advance.
Error message while sending a picture through Picasa’s email by choosing “Gmail”.
Hallo Steve,
To resolve that issue, do the following:
Restart your computer.
Press and release the F8 key continuously when system restarts.
An advanced boot menu will come up.
Choose Safe mode with networking and then press enter.
Wait for a moment to complete the boot process, and then launch Picasa and check.
Carl
Hi Steve,
1. First, test your email default program, for example Gmail account,
Follow steps below:
Go to your image file on your computer and right click on it
Choose Send to>Mail Recipient> Send the email
If email is successful, download the latest version of Picasa to
Fix errors/issues and check if that resolves the problem that you encountered
If email was not sent successfully, the problem is with the internet connectivity
Or with your default email client
2. Another step is to configure your firewall settings, this may be the reason why
You cannot send email in Picasa.
Add Picasa to the list of exempted programs which should not be blocked by your firewall
If you are using multiple firewalls, turned off the windows firewall
Try to send email in Picasa when firewall is turn off. If it works fine, then you
Need to adjust the settings on your firewall.
If it's still the same even if firewall is turn off,clear cache and cookies
3. Configure the internet options by doing steps below both for windows xp and vista
Go to Start Menu > Control Panel > choose internet options
Go connections tab > Lan Settings button
If the box beside "Automatically detect Settings' is checked, uncheck it. do the same if the box is Unchecked.
Thanks
Hi
Check out this Techyv link because this post also addressed about this issue.
Error Emailing a Picture with Gmail
