Sharmin
Posted on - 09/23/2011
I am getting the following message when I was browsing something interesting things! I lost all of my work and data history after getting this message from internet. The message is also showing the more details about this error. But those are extraordinary language which is not goes with me. How can I solve the problem?
Error message while showing web address.
Usually when an error message is pop-up, this is something to do with improper way of Internet usage when browsing the Internet. The simple solution is to close and re-start the sessions again.
If it continues doing this way, then you have to think the second time if you want to do it again of just simple do something else.
In the post you have made, I don't see what error message is. Or I may just simply misunderstood your posting. But a simple restart what your doing usually fixes the problem.
Hello Sharmin,
These types of errors are not of website address errors. These errors are generated by browser.
Usually Google Chrome shows this error. It seems that your browser has been crashed or attacked by a virus. When browser crashed, it erases all the offline data, browsing history, saved passwords and everything from cache and cookies.
To resolve this problem, just uninstall your browser, restart your computer and reinstall it.
But Google chrome can makes this situation again. You should try to install updated version of Fire Fox or any other browser.
I hope this will help you to resolve your problem.
Thanks
