Error message while trying to migrate Tally 7.2 Data to Tally 9
Hello experts,
I am using Windows XP Professional System. I have installed Tally 9 on it. When I wanted to Migrate Tally 7.2 Data to
Tally 9, I found the following Error message:
'Internal Error. Contact Tally Solutions.'
Software Exception C0000005
(Memory Access Violation)
OK
After I select OK A Yellow display shows with this Error :
Error!
Migration is unable to reach Tally 9 server!
Post Request Failed!
(Press 'Enter' to Continue)
Please help me to solve it!
Answered By 0 points N/A #154041
hello Christ Hilyard,
When a system file become broken or missing Because of the unstable of the system computer's maintenance will be improper. when your computer overloads with too much of data usually access violation problems happens,
* Shutdown
*startup problems
*slow pc performance
*system freezes
*Lock-ups
*installation and blue screen, such things can include as symptoms of access violation problems. To diagnose scan and repair your computer download an access violation problems repair tool and fix your problem.
I can give you another solution for tally 9
1. Check your computer memory first your RAM should be mini mum 500MB1GB,yor problem should solve after you doing these,
2. Open tally.ini file now set default companies = no.save your file and back to tally. Again go to company information menu and press CTRL+ALT+R and rewrite that company
Answered By 590495 points N/A #154042
Here’s how to properly migrate from Tally 7.2 data to Tally.ERP 9. In Tally 7.2, double-click on the file “Tally72migration.exe” to start the data migration. Both the Tally 7.2 and Tally.ERP 9 data migrations will begin simultaneously in individual screens. After Tally.ERP 9 has been loaded, you will see “Ready for Migration” in the Migration Message pane. Select Migrate Data. In Select Company For Migration, choose the company from the “List of Companies”. See image.
In Tally.ERP 9 Data Migration Tool screen, select Yes to begin the data migration. The “Types of Masters” and “Types of Vouchers” that should be migrated from Tally 7.2 are displayed in the Migration Information screen. Tally.ERP 9 will prompt you with “Migrate Yes or No”. Click Yes to continue. See image.
During the process, the Tally.ERP 9 calculator pane shows the Masters and Vouchers migrated to Tally.ERP 9. See image.
When the migration process is complete, you will see the message Migration Completed Check Statistics. Any errors committed during the migration process will also be displayed in the Migration Message pane indicated in red color. See image.
