Error message while trying to use QuickBooks 2012
I was trying to use Quickbooks 2012 on my pc, but I received and an error message “Error 1334”.
What does an error mean?
How can I fix this problem?
Hey Emily!
This problem is common for QuickBooks users. There are three possibilities of this error.
Well there are three solutions to solve this problem. I will explain you one by one.
Solution 1: If this error occurs while launching the program)
Solution 2: (If error occurs when you upgrade or install the QuickBooks)
Solution 3: (By replacing Data1.cab from CD)
Insert your QB CD in CD/DVD rom.
Open My computer > Cd/DVD drive > Copy Data1.cab
Now open the Quickbooks installed folder in your computer (Default is, C:Program filesintruitComponentPconfig.
Here press right click on Data1. cab and rename it as Data1.old
Now right click in Pconfig folder and press Paste.
Now start your QuickBooks. It will work
Thanks
Notifications
