Error message while uploading the documents of Share Point Grid View
I made a Share Point Grid View and uploaded the documents. When I try to save the file, an error message appears that I should check the document out (The source code, and file address that I have made is attached). Upon saving the document, an error message appeared.
Can somebody here understand JavaScript programming?Â
The file "http://172.16.10.238:101/sites/SEWS/Documents/SharePointProjectItem.spdata" is not checked out. Â You must first check out this document before making changes. Troubleshoot issues with Microsoft SharePoint Foundation. Correlation ID: eb1a73ba-2864-4ffa-8cb8-bc2b80022bb3 Go back to site.
The code is as follows:
using (SPSite mySite = new SPSite(SPContext.Current.Web.Url))
            using (SPWeb myWeb = mySite.OpenWeb())
              SPList list = myWeb.Lists["Documents"];
              string strListId = list.ID.ToString();
              string strWebUrl = SPContext.Current.Web.Url.ToString();
              //View Properties template
              MenuItemTemplate mitViewProp = (MenuItemTemplate)mtName.FindControl("mitViewProp");
              string strViewUrl = strWebUrl + "/Documents/Forms/DispForm.aspx?ID=%ID%";
              mitViewProp.ClientOnClickNavigateUrl = "javascript:OpenPopUpPage('" + strViewUrl + "')";
              //Edit Properties template
              MenuItemTemplate mitEditProp = (MenuItemTemplate)mtName.FindControl("mitEditProp");
              string strEditUrl = strWebUrl + "/Documents/Forms/EditForm.aspx?ID=%ID%";
              mitEditProp.ClientOnClickNavigateUrl = "javascript:OpenPopUpPage('" + strEditUrl + "',RefreshPage)";
              //Check In template
              MenuItemTemplate mitCheckIn = (MenuItemTemplate)mtName.FindControl("mitCheckIn");
              string strCheckInUrl = strWebUrl + "/_layouts/checkin.aspx?List=" + strListId + "&FileName=" + strWebUrl + "/Documents/%FileName%";
              mitCheckIn.ClientOnClickNavigateUrl = "javascript:OpenPopUpPage('" + strCheckInUrl + "')";
              //Check Out template
              MenuItemTemplate mitCheckOut = (MenuItemTemplate)mtName.FindControl("mitCheckOut");
              mitCheckOut.ClientOnClickScript = "javascript:alert('test function calling from server site event.')";
Please give suggestions on how to make my SharePoint project work.
