Hello all,
I am having an error regarding DWR (I have the jar 3.0 version).
While using DWR, I am getting an error pop up (Please see the screenshot attached below) saying:
Error input parameter.
See logs for suggestions.
Empty Input parameter See log for suggestion
OK
My browser is internet explorer 8.0. Though I have found a solution for this, if I delete all the cookies of my then this error disappears, but it gets back soon.
I am looking for a permanent solution. Please anyone help me on this.
Thank you very much.
Error message while using DWR
Have you seen the logs? It would be helpful if you provided a copy of the logs. By seeing the logs the perfect solution can be found out.
As you say you have found a temporary solution by deleting the cookies, continue doing that every time you run the application. If you want a permanent solution then you need to disable cookies permanently. Follow the steps below to disable cookies permanently:
1. Go to Control Panel on your computer and click on Internet Settings.
2. In the internet settings window, click on cookies tab.
3. Deselect the save cookies to computer option. Click apply and then click ok.
Now, restart your computer and then run the application. As the cookies will not be saved on your computer, you will not face the error.
