aziz2k9
10 points
Posted on - 09/18/2011
HI, I have a problem in microsoft visual studio project
I have an application named GlobalHookDemo in Microsoft visual studio 2010 which is coded in c# language. When I debug or run the GlobalHookDemo program, the Microsoft visual studio compiler returns an error.
Error is:
Error while trying to run the project: Unable to start program D:DocumentsVisual Studio 2010Visual Studio 2010Projectsclipboard sum solverbinDebugGlobalHookDemo.exe
Error in Microsoft Visual Studio 2010
hi i have little bit experience about this problems as i m also a programmer this error related to your system not your program so first of all install your VB in that drive in which you installed your Microsoft Windows hopefully it will remove your error and if your error remains constant then you must need to reinstall your software
thanks
Hello Aziz,
I have seen this problem before while debugging one of my web application. This errors occurs when you create a web application in Visual Studio.Net. and then you press F5 to debug the application it returns the following error: Error while trying to run the project. To get rid of the following error please follow the simple steps:
1- Go to Start -> programs -> Administrative tools -> Local security policy
2- Now select User rights assignments
3- Now choose Impersonate a client after authentication
4- Now click Add button
5- Click on the ASPNET and click ok
All done, you will not receive the error again.
Thanks
