Error in Miracle 1.47 is not working with me when tried to download update 1.47 and install. When I open miracle exe from desktop I got this error message. I really need your help to resolve this issue. Any assistance would be appreciated.
Thanks in advance.
When i press ok again this error appears.
Invalid filename.
OK
Error: I/O error 103. when press ok software open but not in working mode not connect nothing happened.
Error in Miracle 1, can’t download update 1.47
Many programs which might not have followed proper coding techniques, treat file names differently because of the characters conflict with file hierarchy of that system. Such software applications cannot indicate the file name that OS treats as invalid, instead the former displays "Invalid file name" error message when you open a program or media file.
So in your case the solution would be to open "my computer", then C drive and go the program file (Miracle Box folder). Create a folder called "Logs". This method will evade the program to pop up this error.
