Error Mobile Phone MPEG-4 while converting files
Good Day everyone!
Good Day everyone!
Since a music video or MTV is also a video, check that the file you are converting is indeed a video and not a music file or audio file because the setting you are using is MP4 (*.mp4) intended for videos. You can’t use this profile or format for audio files like MP3 (*.mp3) because it might trigger an error.
Check the format of the file you are converting before starting the conversion and make sure that the file is really a video. Also, try using other converters like Format Factory. The latest version at the moment, Format Factory 4.4.1.0, supports Windows Vista, Windows 7, Windows 8.x, and Windows 10. Format Factory dropped support for Windows XP starting with this version.
See if this works. Note: Format Factory will offer additional software during installation so read the information carefully before clicking each button. This is to avoid installing unwanted software on your computer.
