Error with MS Internet Explorer
Hello
I got a problem in my explorer.
When I select the close option, then an error appears. Here is the error:
Restrictions
This operation has been cancelled due to restrictions in effects on this computer. Please contact your system
Administrator.
        OK
I am using (OS):- Microsoft Windows XP Professional Version 2002 Service Pack 3. And Hardware: – Intel(R) Pentium(R) 4 CPU 1.60GHz, 504MB of RAM.
When i select the close button, this error message happens.
Please give me a solution.
Thanks a lot.
Answered By 10 points N/A #149812
Hello Damon,
You are getting that error most probably because you have restrictions on your computer that are preventing MS Internet Explorer from executing correctly, or you windows MS Internet Explorer may be corrupt. To fix the issue, you will need to do the following:
  • Make sure that you have logged onto the computer with an account that does not have restrictions on certain applications. If you are logged on with the guest account you will need to log out and log in with the administrator account.
  • If the error still continues after the above workaround, go to the control panel and uninstall MS Internet Explorer. Download a fresh setup application from the internet and install it.
Hope this helps.
Carl
