An error with my angry birds open gl download.
Hi to everyone,
I downloaded an angry bird game yesterday in my windows 7 starter 32 bit operating system hp laptop but unfortunately there is an error occurred that requires open gl.
What should I do to keep the game running and visible?
Thank you.
Best Answer by Charmaine Hardy
Answered By 0 points N/A #185464
Hi Jeremy,
It seems that your are getting that error because your graphics driver is outdated. One solution is for you is to:
1. Search for latest drivers for your graphics card over the internet.
2. After you find a driver, download the driver and install the driver.
3. Restart your computer.
Another possible solution to that problem is:
1. Right click on your desktop.
2. Click on Personalize.
3. Click on Display.
4. Click on Change display settings.
5. Click on Advanced settings.
6. Click on Troubleshoot.
7. Click on change settings.
8. You will see a slider, drag it to Full.
9. Apply changes.
That's it. I hope those solutions that I gave you helps.
Answered By 0 points N/A #185463
Hi Jeremy!
You may need to reinstall your video card driver. Update it if a newer version is available.
Another way to fix the problem, if reinstalling the video card driver won't work is by:
  1. Go to Control Panel.
  2. Click on Display.
  3. Click on Advanced.
  4. Click on the Troubleshoot tab.
  5. Set Hardware Acceleration to Full.
  6. Click on OK.
If it still won't solve the problem, reinstall Angry Birds.
