Bernard856
Posted on - 11/27/2011
Hello Experts,
I got the error message when try to have an Ubuntu security update.
It’s seemed there’s no problem with other application that I download like Wine and Virtual box.
I Have checked my internet connection and have it test speed, no problem.
Has anyone experience this error that I’m facing please give any inputs.Â
Error :
An error occurred
The following details are provided:
W: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/x/xorg-server/xserver-xorg-core_1.3.0.0.dfsg-12ubuntu8.1_i386.deb
403Â Forbidden
Thanks!
lee hung
75 points
Error in my Ubuntu security update.
Hello Bernard856,
It may be just a temporary occurrence of such an error and therefore I will advise that you wait for sometime and then try running the update again and see if it will work. Maybe the latest update has not been posted to the Ubuntu site yet and trying later may work.
You should also just check your internet connection one more time and verify that it is indeed strong enough. If you have queued any downloads pause them, and if you have opened many tabs in the browser you are using close them because they may be taking up a lot of bandwidth hence making the download of the update unsuccessful.
Hope this helps.
Regards
Lee Hung
