diegobro
Posted on - 02/07/2012
I would like to remove some Windows programs and run slim driver to speed up the performance of Asus UX. There was no problem until I downloaded iTunes. When I am trying to download the iTunes an error message is coming. I have searched in the internet and found that it is happening because of some framework.net. I have repaired the same but there was no change in the result. I have lost my Windows 7 disk otherwise I can re-install the Windows. If anybody knows how to fix this problem, please let me know. I will be thankful for all help and support.
Error on my windows 7 after downloading iTunes
HI Diegobro,
It is not very difficult problem. Because it is very easy to solve. Just follow what I say. When I was trying to first time to install itunes then I got same error message from installer. Then windows say: Windows Installer Service could not be accessed.
So please check your windows startup mode. Ensure it is not running safe mode. I am using the Windows 7 Home addition. You need to change your net framework that is provided by Microsoft. So don’t wait and download Microsoft net framework latest version for your windows 7. You can also repair your .net framework. But I require you please change new version.
Mind that, before downloading latest net framework please remove your old net framework version from control panel and then install new net framework quickly.
After installing net framework restart your pc.
And then retry. I hope that it will be solved.
diegobro
The problem has been solved. Thank you for giving me the solution for my windows problem. All i did was follow what you said.
Great help. Site is awesome.
Thanks Techyv, surely this site has great tech support.
