Error N8011 when starting Silverlight
I got an error N8011 when trying to open the Silverlight window from within the Application Storage tab. I have tried different browsers such as IE7, Chrome and Firefox but none works.
How can I fix it?
How can I fix it?
Hi Homer Briones,
Your problem won't be resolved by switching browsers, Error code N8011 is Application Storage Error.
This is the solution on how you would resolved that issue:
The first thing you need to do is open the Silverlight Configuration. You have two options:
1st: You can select any Silverlight application, right-click, then click Silverlight and the dialog box will appear.
2nd: Open the Start menu, click Programs. Look for the Microsoft Silverlight folder then click Microsoft Silverlight.
After doing any of the two the Silverlight configuration box will appear, it has 6 tabs: About, Updates, Playback, Webcam/ Mic, Permissions, and Application Storage. Click the Application Storage tab.
o
In the Application storage tab, click delete all.
After deleting all the web sites, click OK.
For solving this problem you can try the following. Your browser’s private browsing mode is restricted Netflix from the storing setting on your PC.
You should turned off the private mode of browsing in your browser and try again.
Follow the following step
Go Start Menu and then RUN and type gpedit.msc.
You should navigate to the following Folder.
Computer Configuration / Administrative Templates / Windows Components / Internet Explorer / InPrivate
On the right-hand side, check the Inprivate folder and double-click on it. You should choose enabled option and Click on OK.
You can also turn it off for only the user that is currently logged in by just going under the user configuration.
If you keep looking, you will also see the option for turned off Inprivate Filtering, not collecting Inprivate filtering data and also setting the Inprivate folder Threshold.
If the above does not work, invalid website listed in my Silverlight configuration user App Storage. You should delete this folder.
C:Users%username%AppDataLocalLowMicrosoftSilverlight
Hope the solution will helpful for you
