Minty nicky
50 points
Posted on - 08/22/2012
I am getting the following error "Error Number: 0x800CCC0F" in the Outlook Express:Â Â "Your server has unexpectedly terminated the connection. Error Number: 0x800CCC0F"
Do you have an idea on what is going on?
Any help will greatly be appreciated.
Error Number 0x800CCC0F in Outlook Express
To solve this problem start Outlook Express in safe mode. A new email profile needs to be created. If there is any suspicious message delete them all. Check all SMTP email addresses are valid in the distribution list. For better usage you can also get a fresh copy of Outlook Express. You also check the Windows Firewall allows the program run. Your current Antivirus running with your system may also be responsible for the error. So check them all. However, the mentioned error message indicates that the server has interrupted or terminated the connection. If it still continues report to the Server Administrator or ISP (Internet Service Provider).
I hope you understand it.
