Error number 2323: ICA Client Configuration Manager
Could not find an ICA file or Appsrv.ini entry corresponding to (application name)
When an application begins, this error message is produced;
error number 2323
Error number 2323
ICA  client Configuration Manager: Could not find or Appsrv.ini entry corresponding to (notepad). Please check contact your administrator.
Anyone has clear ideas about this error, please he (she) guides me to solve it quickly.
Answered By 0 points N/A #149957
This is a common problem that most people face during these days. I know two ways that can help you fix the problem. Just follow these steps to get rid of the errors.
Step 1:
If you want to fix error runtime2323, you can try a free registry scan for your computer. I would like to inform you that this is the most important step to fix runtime error 2323. You will also be able to avoid another runtime error in the future. There are a lot of numbers of various registries repairing tools available on the Internet that can scan, analyze and also fix the problem.
Aside from fixing your computer’s runtime error 2323, these tools will also remove some invalid shortcuts, registry errors, duplicate files and repair DLL files. Also, your computer will be free from error messages and slow performance as other registry errors will be fixed aside from the runtime error 2323 on your PC. On the contrary, it may harm your system and bring more troubles even your system can crash.
Step 2:
Since runtime error is linked with missing DLL files, it can be re-registered to get rid of the runtime error 2323. If you want to
re-register the file, follow the steps given below:
(a) Select Start-Run
(b) Then type in regsvr32 c:windowssystem32dllfile to Download repair tools.
(c) Then restart your PC
If you can’t find the exact file on your PC, you must download it from the internet and save it to the right place.
Thank you.
