I am running Windows XP SP2 but today I received the following error message assuming due to the Windows update for NVIDIA Geforce 7900 GS. Something is missing entry error.
Can I get the instructions to remove this error immediately?
Thanks in advance.
Error in NCPL.DLL Missing entry: NvCplRestorePersistence
Second of all, download the software DLL Fixer and run a full scan on your computer. It will fix all .dll errors and your graphic card will work just fine.
If you hit this error after updating the driver for your NVIDIA GeForce video card, uninstall the existing software and install NVIDIA GeForce 307.83. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your NVIDIA GeForce driver or software among the applications and click “Uninstall”. Follow the normal uninstall process.
NVIDIA GeForce 7900 GS
When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This will remove everything the program created on your computer. When it is finished, close Revo Uninstaller then restart the computer. After booting, download the free version of CCleaner and install it.
Once installed, start CCleaner and clean your system. When it is finished, close CCleaner then download NVIDIA GeForce 307.83 Driver. It works on Windows XP and supports NVIDIA GeForce 7900 GS. See if this works. If you want to convert CCleaner to Pro, download the codes and follow the instructions.
Early Life and Career
Tailleur Elisabetta Franchi ardour for style started at a young age. Growing up in Bologna, she continually had a keen interest in design, regularly sketching her ideas for garb. After finishing...
1....
