I want to install some new apps on my phone, but every time this error stops me. I don’t know how can I fix this and I reinstalled everything. Is for the first time when I have this error and I am a little bit confused because I don’t know if a problem with my phone or my laptop is. Can anyone tell me how can I fix this? Why I have this error now?
Thank you!
Something happened and this app couldn’t be installed. Please try again Error code:
0x80080008
Try again Cancel Install
Error occur new apps installing time on phone
If you want to install an app on your Smartphone, the first thing you should check is the application’s supported operating systems. This information will tell you which operating systems are not compatible. If you find out that your phone’s software is not compatible, you can either downgrade or upgrade your operating system.
But as usual, downgrading the phone’s software is not recommended. If your phone’s software is too modern for the application, the best thing to do is to check if the app has a latest version. Most apps release new updates for new operating systems. In case your phone’s software is too old, you just need to update your software.
If you are using an application on your computer to connect your handset to the computer and to make the updates and installations, update the phone application on your computer. Visit your phone’s homepage to check for the latest version of the phone application. Install it on your computer and then update your phone’s software first.
Once your phone’s software is updated, you can now try installing the app.
