An error occurred about drop box silent install.
Hello experts,
An error occurred about drop box silent install. When the installation process is going on my computer with a windows 7 starter operating system was automatically restarted without any permission from me. I was bothered about the situation, I need your advice. I installed it three times but the same problem occurred. Thank you.
Best Answer by Smith Thompson
Answered By 0 points N/A #180530
Hallo Danield,
Have you retried the installation since that occurred? If you retried and got the same issue then it is most probable that the setup that you are using to install is the one with an issue. You will therefore need to get another setup, if you are downloading it from the internet make sure you get if from a trusted site.
Nicke
Answered By 10 points N/A #180532
The program you are trying to install is possibly corrupt and that's the reason for the failure of your computer. So i will ask you to run in safe mode and install the software and if the same problem occurs then you need to check the software on another  computer and then you will be sure about it that its programs error or its a computer fault.
Smith Thompson
