An error occurred in checksum hard disk tool
After running my GSmartControl, this error appeared "Error in Attribute Data structure: checksum error". Is there a problem with my checksum hard disk tool? Or does it shows a failure in the hard disk?
Please help.
Best Answer by Adish Pescadero
Answered By 60 points N/A #148111
Hi Jaclyn Andree,
I have made a research about your concern and it is seems that it has a lot of possible solutions in the internet. I have attached link of a good site that would be a great reference to your concern.
ASKUBUNTU: Checksum Errors From Hard Disk
If you want to have a broaden reference to your concern, you can join the discussion in this forum:
Freelance Forum: Disk Got Strange name after the switch
Answered By 0 points N/A #148110
Hello Jaclyn,
The error message "Error in Attribute Data structure: checksum error" means that your GSmartControl has become corrupted or your hard disk drive is sending back bad SMART data.
It doesn't indicate a hard disk crash or failure. You can try running the Disk Utility program that comes with Ubuntu and see if your hard disk is able to read the bad SMART information or not.
You can run the "Disk Utility" program by following these steps:
1. Open "System" menu and select "Administration".
2. Select "Disk Utility".
I hope this solves the case.
