An error occurred with ComboFix
I am trying to install ComboFox on my Windows 7 Machine and I am unable to install because of this weird error message. When I attempt to install the following problem occurs. How can I fix this issue? Have you any idea to resolve this matter? I would be grateful to you. Thanks in advance.
Combofix
C:combofix~.a refers to a location that is unavailable. It could be on a hard drive on this computer, or on a network. Check to make sure that the disk is properly inserted, or that you are connected to the internet or your network, and then try again. If it still cannot be located, the information might have been moved to a different location.
