Error occurred during installation process of Steganos Security Suite 2007
Hi All,
I have been trying to install Steganos Security Suite 2007 without much success. The installation fails with an ‘Error opening file for writing’ message. I tried aborting the current installation and tried installing again making sure that I had no other programs open. Again I get the same error. I remove the installer and downloaded a fresh version of the installer. But even after trying to install from this, the problem persists. How can I resolve this issue? Is my installer corrupted? I hope someone can help me with a solution for this issue. Thank you all for spending your time on this.
C:WINDOWSsystem32SatSrv.exe
Click Abort to stop the installation,
Retry to try again, or
Ignore to skip this file.
