An error occurred during the installation Process of SugarSync for Outlook
Hello!
Today, I was trying to uninstall SugerSync [for the Outlook emailing Product] and faced a new error message; it is requested to all of you that please help me in connection with the solution of the above concern.
I am sharing the screenshot of this error message, please.
SugerSync for Outlook
Error Heading: SugerSync for Outlook
Error 1001. InstallUtilLib.dll: CorBindToRuntimeHost (hr=0x80070003): The system cannot find the path specified.
It is highly requested to please help me in connection with the above concern.
Best Answer by Keith J Harmon
Answered By 10 points N/A #170993
Dear David,
If you face this error that means that your operating system is missing .NET Framework.
All you need to do to resolve this problem:
1. Download  .NET Framework 4.0, you can download it from here
http://www.microsoft.com/en-us/download/details.aspx?id=17851
This is just the installer.
2. Follow the setup wizard to install .NET
3. Now try to uninstall SugarSync for Outlook.;
– You can uninstall SugarSync from Control Panel > Add and Remove
– Or for better results you can uninstall it using Revo Uninstaller Pro
You can try it for free or buy it from here:
https://www.revouninstaller.com/
This software allows you to uninstall stubborn programs and delete leftover data after regular uninstall.
Answered By 40 points N/A #170994
Hi
According to your question there is another Techyv post which is also addressed about this issue. Visit that page to get more useful help :  Error when uninstalling SugarSync for Outlook
